Success! Works great, with the added bonus of the smell of new leather! Thanks to S/S Dodge for the pictures on other site, of his shifter mod, as I kinda knew what to expect when taking off top of shifter! Got pictures to email to Ghost, to post fer me, thanks man! Otherwise, here's the skinny; Remove shiftknob, trimring,trimplate under that, and remove plastic snapring under new shiftboot to remove shiftrod/handle ( nope the sixspeed handle DOES NOT come off the rod). Now remove the topcover of the shifter by carefully lifting/prying/popping the four plastic catches, two per side. As this part directs the black slider/cover, remove that also, and the second piece under it that revolves on it, had to leave mine as I didn't want to cut it to remove it past the locknut, danged customizer! Now just snap the new booted trimplate ( snap the new boot assembly to the trimplate first, easiest) back into position, put hole over shaft, install the shift handle, done! Hardest part was taking the top of autoshifter off, without removing console, as the lock tabs are easily lifted from the bottom, but u can do it from the sides/front/back with two tiny screwdrivers. Took picture in a couple stages, and finshed in Park/L kinda stretchs in low, but since I allways use low, think it'll stretch. When I have to get it inspected in August, bet I have to ride with them to put it gear/park tho!
