For REAL carbon fiber - this is the only supplier I use - CJComposites (CHRISTINE) **she carries a Blue twill that you DWB guys would KILL for - if you do not see a color - email her and she will find it if it EXISTS**
Resin is TRICKY - for real carbon fiber, the most EXPENSIVE CF parts makers use ONE of these TWO particular epoxy systems because they have full UV - dry CRYSTAL clear - resist heat better - and DO NOT HAZE or turn dull like polyester and vinyl based resins
EAT-A-BUBBLE (MUCH safer than a butane torch - resin is HIGHLY flammable)
For EAT-A-BUBBLE the ONLY US supplier is KLOCKIT (Makes your resin pour smoother, reduces 95% PLUS of the bubbles, and makes the hardened resin coat CRYSTAL clear - also adds UV)
I found a good tip in the post for covering side mirrors (I think i posted it). The plastic in our engine compartments is VERY hard to get paint and CF to adhere to. I am using tip from mirror covering post - drilling a series of holes in a cover then runninga screw through them - then when you do your first pour - the resin saturates the holes and creates resin "screws" holding the covering fast
Super- Duper ! Carbon fiber steering wheel is definitely and eye candy when you drive It is plug and play !! Want to know more custom steering wheel pls follow IG / FB @GM. Modi-Hub Carbon WEB:GM.Modi-Hub
A forum community dedicated to Dodge Challenger owners and enthusiasts. Come join the discussion about performance, modifications, classifieds, troubleshooting, maintenance, and more!
