SPECIFICATIONS - FLUID CAPACITIES
* fluid capacities/recommended fluids *
DESCRIPTION - SPECIFICATION:
Fuel Tank - V6 Engine 68 L (18 gal.)
Fuel Tank - V8 Engine 72 L (19 gal.)
Engine Oil* - 3.5 L 5.7L (6.0 qts.)
Engine Oil* - 5.7 L 6.6 L (7.0 qts.)
Engine Oil* - 6.1 L 6.6 L (7.0 qts.)
Cooling System - 3.5 L** 10.0 L (10.6 qts.)
Cooling System - 5.7 L** 13.8 L (14.6 qts.)
Cooling System - 6.1 L** 14.0 L (14.8 qts.)
AUTOMATIC TRANSMISSION:
Service Fill - NAG1 5.0 L (10.6 pts.) Overhaul Fill - NAG1 7.7 L (16.3 pts.)♦
Service Fill - 42RLE 3.8L (4.0 qts) Overhaul Fill - 42RLE 8.3L (17.6 pts)♦
♦Dry fill capacity. Depending on type and size of internal cooler, length and inside
diameter of cooler lines, or use of an auxiliary cooler, these figures may vary.
AXLE - REAR
198 MM RII Axle 1.4L (1.5 qts.)
210 MM RII Axle 1.6L (1.7 qts.)
215 MM RII Axle 1.6L (1.7 qts.)
RECOMMENDED FLUIDS, LUBRICANTS AND GENUINE PARTS
ENGINE:
Component Fluids, Lubricants and Genuine Parts
Engine Coolant Mopar ® Antifreeze/Coolant 5 Year/100,000 Mile Formula HOAT (Hybrid Organic Additive Technology)
Engine Oil (3.5 Liter) Use API Certified engine oil. SAE 10W-30 is recommended.
Refer to the engine oil viscosity chart for the correct SAE grade meeting DaimlerChrysler Material Standard MS-6395.
Engine Oil (5.7 Liter) Use API Certified engine oil. SAE 5W-20 is recommended.
Refer to the engine oil fill cap for the correct SAE grade meeting DaimlerChrysler Material Standard MS-6395.
Engine Oil 6.1 Liter) Use API rated SL/CF full synthetic engine oil, such as Mobil 1® . SAE 0W-40 is recommended.
Spark Plugs Refer to the Vehicle Emission Control Information label in the engine compartment.
Oil Filter (3.5 Liter) Mopar ® 05281090 or equivalent.
Oil Filter (5.7 Liter) Mopar ® 05281090 or equivalent.
Oil Filter (6.1 Liter) Mopar ® 05281090 or equivalent.
Oil Filter 2008 5.7 & 6.1 Mopar 4884899AB or equivalent
Fuel Selection (3.5 Liter) 89 Octane
Fuel Selection (5.7 Liter) 89 Octane
Fuel Selection (6.1 Liter) 91-93 Octane
CHASSIS:
Automatic Transmission Mopar ® ATF+4 Automatic Transmission Fluid or equivalent.
Brake Master Cylinder Mopa ® DOT 3 and SAE J1703 or equivalent should be used. Use only recommended brake fluids.
Power Steering Reservoir Mopar ® Power Steering Fluid + 4, Mopar ® ATF+4 Automatic Transmission Fluid or equivalent.
Rear Axle API Certified GL-5 SAE 75W140 Synthetic Gear Lubricant or equivalent.
CAPACITIES: DESCRIPTION U.S. Metric
Fuel (approximate)
3.5 Liter Engines (89 Octane) 18 gallons 68 liters
5.7 Liter Engines (89 Octane) 19 gallons 72 liters
6.1 Liter Engines ( 91-93 Octane) 19 gallons 72 Liters
Engine Oil-With Filter
3.5 Liter Engines (SAE 10W-30, API Certified) 6.0 qts. 5.7 liters
5.7 Liter Engines (SAE 5W-20, API Certified) 7.0 qts. 6.6 liters
6.1 Liter Engines (Mobil 1 0W40, API rated SL/CF full synthetic engine oil) 7.0 qts. 6.6 liters
Cooling System *
3.5 Liter Engines (Mopar ® Antifreeze/Coolant 5 Year/100,000 Mile Formula) or equivalent. 10.6 qts 10.0 liters
5.7 Liter Engines (Mopar ® Antifreeze/Coolant 5 Year/100,000 Mile Formula) or equivalent. 14.6 qts 13.8 liters
6.1 Liter Engines (Mopar ® Antifreeze/Coolant 5 Year/100,000 Mile Formula) or equivalent. 15.2 qts 14.4 liters
* Includes heater and coolant recovery bottle filled to MAX level.
__________________
