HOISTING
1 - DRIVE ON HOIST
2 - FLOOR JACK, VEHICLE EMERGENCY JACK
3 - FRAME CONTACT LIFT (SINGLE POST)
3 - CHASSIS LIFT (DUAL LIFT)
3 - OUTBOARD LIFT (DUAL LIFT)
3 - FLOOR JACK
Refer to Owner's Manual provided with vehicle for proper emergency jacking procedures.
WARNING: The hoisting and jack lifting points provided are for a complete vehicle.
When the engine or rear suspension is removed from a vehicle, the center of gravity is altered
making some hoisting conditions unstable. Properly support or secure vehicle to hoisting device
when these conditions exist. Failure to follow these instructions may result in serious or fatal
injury.
CAUTION: Do not position hoisting device on any suspension component, including the front or
rear suspension crossmembers. Do not hoist on the front and rear bumpers, the lower radiator
crossmember, or the front engine mount. Do not attempt to raise one entire side of the vehicle
by placing a floor jack midway between the front and rear wheels. This practice may result in
permanent damage to the body.
When properly positioned, a floor jack can be used to lift the vehicle and support the raised vehicle
with jack stands.
A floor jack or any lifting device must never be used on any part of the underbody other than the described areas.
