How to display DTC "Diagnostic Trouble Codes" on Dodge Challenger.
Get in the car, close the door. Perform the following steps fairly quickly (in less than 3 seconds) :
Turn key to ON
then back to ACC
then to ON
then back to ACC
then to ON
If there are any stored codes, they will appear immediately, in place of the odometer. For instance an "INTAKE AIR TEMPERATURE SENSOR CIRCUIT HIGH" error will set a code of P0113.
Schematic of a DTC code:
DTC is made up of 5 digits.
The figure below demonstrates the composition of a DTC. With this information it is easier to troubleshoot a DTC without knowing the description of the code.
X X X X X
Digit 1: B-Body, C-Chassis, P-Powertrain, U-Network
Digit 2: 0-SAE, 1-MFG
Digit 3: 1-Fuel and Air Metering
2-Fuel and Air Metering (Injectory Circuit)
3-Ignition Systems or Misfire
4-Auxiliary Emission Controls
5-Vehicle Speed Control and Idle Control System (ETC)
6-Computer Output Circuit
7-Transmission
8-Transmission
Digit 4,5: Fault (00-99)
Here is a list of DTC codes and meanings:
DTC P1622 Cylinder Select
DTC P1623 Transmission Temp Pull-Up Resistor
DTC P1624 Customer Snapshot Requested - Data Available
DTC P1625 TCM System Reset
DTC P1626 Theft Deterrent Fuel Enable Signal Not Received
DTC P1627 A/D Performance
DTC P1628 ECT Pull-Up Resistor
DTC P1629 Theft Deterrent System - Cranking Signal
DTC P1630 Theft Deterrent Learn Mode Active
DTC P1631 Theft Deterrent Start Enable Signal Not Correct
DTC P1632 Theft Deterrent Fuel Disable Signal Received
DTC P1633 Ignition 0 Switch Circuit
DTC P1634 Ignition 1 Switch Circuit
DTC P1635 5 Volt Reference Circuit
DTC P1636 PCM Stack Overrun
DTC P1637 Generator L-Terminal Circuit
DTC P1638 Generator F-Terminal Circuit
DTC P1639 5 Volt Reference 2 Circuit
DTC P1640 Driver-1-Input High Voltage
DTC P1641 Malfunction Indicator Lamp (MIL) Control Circuit
DTC P1642 Vehicle Speed Output Circuit
DTC P1643 Engine Speed Output Circuit
DTC P1644 Traction Control Delivered Torque Output Circuit
DTC P1645 Evaporative Emission (EVAP) Vent Solenoid Contorl Circuit
DTC P1646 Evaporative Emission (EVAP) Vent Solenoid Control Circuit
DTC P1647 Driver 1 Line 7
DTC P1650 Control Module Output B Circuit
DTC P1651 Fan 1 Relay Control Circuit
DTC P1652 Powertrain Induced Chassis Pitch Output Circuit
DTC P1653 Oil Level Lamp Control Circuit
DTC P1654 Cruise Control Inhibit Output Circuit
DTC P1655 EVAP Purge Solenoid Control Circuit
DTC P1656 Driver 2 Line 6
DTC P1657 1-4 Upshift Solenoid Control Circuit
DTC P1658 Starter Enable Relay Control Circuit
DTC P1660 Cooling Fan Control Circuits
DTC P1661 MIL Control Circuit
DTC P1662 Cruise Lamp Control Circuit
DTC P1663 Oil Life Lamp Control Circuit
DTC P1664 1-4 Upshift Lamp Control Circuit
DTC P1665 Driver 3 Line 5
DTC P1666 Driver 3 Line 6
DTC P1667 Reverse Inhibit Solenoid Control Circuit
DTC P1669 ABS Unit Expected
DTC P1670 Driver 4
DTC P1671 Driver 4 Line 1
DTC P1672 Low Engine Oil Level Lamp Control Circuit
DTC P1673 Engine Hot Lamp Control Circuit
DTC P1674 Tachometer Control Circuit
DTC P1675 EVAP Vent Solenoid Control Circuit
DTC codes continued on next message.
Turn key to ON
then back to ACC
then to ON
then back to ACC
then to ON
X X X X X
7-Transmission
8-Transmission
DTC P1670 Driver 4
