that does look sweet but I agree on drilling the holesI really like the dash mounted gauges on the SMS Challengers. Too bad it probably requires a HOLE being drilled into the dash pad to run the wires, etc. On a side note, I can't wait to see Jason's pillar pod install!
You have some bad information. The Razors edge pillar pod is compatible with the A pillar air bag that all challengers have. I have one right at my feet waiting to install it in the spring. I have pulled both side A pillar trim and there is no magic, just two small nylon straps like pull ties. The only issue is that it is covered with fabric that matches the headliner. You need to send in a passenger A pillar trim and they will cover it and all matches. I'll order the passenger trim piece this weekend and when it comes in send it off and be all set for spring. I need a boost gauge and air/fuel gauge.^ I ordered the SMS gauge pod, see the pillar pod won't work on some Challengers as they have the airbag in the pillar, I'd rather have a hole that can be patched then a face full of plastic during an accident.
this is interesting. i was of the same mind set as X and had heard that with the airbag you were taking big chances with this style of gauge pod.You have some bad information. The Razors edge pillar pod is compatible with the A pillar air bag that all challengers have. I have one right at my feet waiting to install it in the spring. I have pulled both side A pillar trim and there is no magic, just two small nylon straps like pull ties. The only issue is that it is covered with fabric that matches the headliner. You need to send in a passenger A pillar trim and they will cover it and all matches. I'll order the passenger trim piece this weekend and when it comes in send it off and be all set for spring. I need a boost gauge and air/fuel gauge.
No critique here, just getting the proper info out.
