fix it | Challenger Life Forums
fix it
Discussion in 'Exterior Mods' started by Hesser, May 3, 2010.
  1. Hesser
    Hesser Well-Known Member
    Apr 27, 2010
    1,866
    49
    The Woodlands Texas
    What is the fix for the holes for the front plate bracket? Who in Houston has the sequential turn/brake lights?:readthemanual:
  2. sickr bee
    sickr bee Well-Known Member
    Nov 13, 2009
    2,557
    64
    Dallass, Texass
    Seen on another site, that someone makes body color plugs, for the bumper holes. I've started to add hood stripes, with the bumper stripes like Intimidaters in Red, so I can remove plate/cover holes. Mine was dealer installed, so I'm stuck with it as U, BUT if u will remove the plate mount, and redrill the mount screw holes in the bracket to the top edge of the frame, and it lowers the plate bout an inch or so on your bumper, which changes the angle just enough to make it look a lil better. As for the web kit, think Houdini just got one, so I'll let him answer that part.
  3. Big Mike
    Big Mike New Member
    Feb 6, 2010
    508
    17
    Billerica, Massachusetts
    Yes sir... it's http://bumperplugs.com/BPindex.html I saved it because I was debating on using em.
  4. Houdini
    Houdini Platinum Level Supporter
    Aug 18, 2009
    3,505
    67
    S.E. MI
    Yes, I do have them, but I'm not from Houston. If you want to see them in person, it's only a 22 hour drive :lol:
  5. Hesser
    Apr 27, 2010
    1,866
    49
    The Woodlands Texas
    I was able to seem them in person over the weedend. Several of the other Challengers had them that were on the Country Run we did. I have seen
    two types advertised, one that runs from the flaser, the other that can be
    programmed. What do you have and what would you suggest.
  6. Houdini
    Aug 18, 2009
    3,505
    67
    S.E. MI
    I have the WebElectric - no programming, no cutting or splicing wires. I'm happy with them.
  7. GHOSTDANCE
    GHOSTDANCE New Member
    Nov 11, 2009
    1,683
    45
    San Antonio Texas/Edinburgh Scotland/Puebla Mexico
    you need to post that link in exterior mods - :)
    ps - speaking of exterior mods - are you going to make the Riverfest run in Bandera on June 27?? if so - will give you a link to order green vinyl striping and I'll do your rims while we are there
  8. Houdini
    Aug 18, 2009
    3,505
    67
    S.E. MI
    I moved the whole thread. :thumbupright:
    I had missed that it was in the wrong forum.
  9. Hesser
    Apr 27, 2010
    1,866
    49
    The Woodlands Texas
    Still figuring out all the places to go here. Thanks for the move. Next time, and it very well may happen again that I f*ck up, tell me so. :doh:
