Hood dust strip | Challenger Life Forums
Hood dust strip
Discussion in 'Dodge Challenger General Discussions Forum' started by hada71rt, Jun 27, 2015.
  1. hada71rt
    hada71rt Member
    Jun 7, 2013
    102
    11
    18
    Carol Stream, Il.
    I didn't see anything posted on this so..
    My hood dust strip finally went so here's what I did..
    1.) Used pieces of blue painters tape to mark the top edge of the dust strip for reference. (That's what they call it)
    2.) Removed the rivets with a small star driver screw driver by putting the end on the center of the rivet and wacking it with a rubber mallet. This drives the rivet pin down into the center of the rivet and allows it to be removed with a plastic removal tool.
    3.) Removed the cup holder plastic (SRT thing) and cleaned the face where the strip was with alcohol.
    4.) Using 3/4" wide x 7/16" thick black self stick weather seal, available at any home center, I affixed it to where the previous strip was using the blue tape as a guide.
    5. This seal, although called black actually looks more like a dark gray, so to get a finished look I cover it with "Scotch" black plastic tape. (See attached pics)
    A couple notes, when I applied the black tape the car, which is black, was sitting with the nose outside the garage in the sun and the engine was hot. As I applied the tape it became so hot to the touch it seemed to bond to the foam.
    I drove the car several times afterward and the tape stayed bonded to the foam.
    So far so good and no rivets or screws required. If I have a problem in the future I'll post it.
    Nice thing is it's a cheap fix and easily removed if you wish to go back to the original.
    The attached PDF shows what the Foam strip, top image, looks like compared to the actual section of dust strip. The vertical part of the dust strip is very stiff compared to the seal part which is the part that's tearing. I think that maybe the two different types of rubber are bonded.
    Hope this helps somebody that has a similar problem..
    (OO [::::::::::::::::SRT:::] OO)
  2. IntimidatorR/T
    Top Poster Of Month
    5,418
    153
    last time that happened to me , i just ripped it off and left it that way, that piece from the dealer cost about $45. I replaced it on my first challenger.
  3. idmtfirefighter
    idmtfirefighter Well-Known Member
    Jan 11, 2010
    1,646
    finally pulled mine last weekend...it was about 25% ripped from the driver side to passenger side
  4. idmtfirefighter
    Jan 11, 2010
    1,646
    after pulling mine off, washing the car, and driving through heavy rain, I have seen no more or less water/dirt in my engine compartment
2010 challenger hood gasket
2010 dodge challenger srt8 hood weather stripping
2012 challenger hood seal rivets
2013 challenger hood rubber weather strip
2015 challenger hellcat hood weather stripping
challenger dust seal
dodge challenger cup holder inserts
how to recover plastc rivets from hood seal on challenger
how to replace the hood seal 2015 challenger
pom rivets for 2010 challenger hood seal
rivets 2010 dodge challenger hood seal
rivets for challenger hood weather strip
what size are pom rivets 2009 challenger hood seal
what size plastic rivets to put up hood seal for 2009 dodge challenger srt8
