1 - 3 of 3 Posts
Hello all,
Just recently my car navigation would stop working randomly, after a few hours of driving around/running errands. The map would disappear and a message would display. Something along the lines of "No navigation system installed." It later starts working again randomly. This happens a few times a week...
Also, not sure if this is related to problem. But the NAV light flickers every now and then as well...
Is there an easy fix for the NAV button?
Looking into buying an aftermarket Pioneer deck with backup cam
SOUNDS LIKE YOU GOT A RADIO PROBLEM. MY 2017 RAM HAS A RADIO ISSUE AS RIGHT BEFORE THE LATEST UPDATE, IT WOULD SHUT OFF WHEN YOU TURNED THE KEY OFF AND OPENED THE DOOR. AFTER UPDATE IT STAYS ON FOR ABOUT A MINUTE AFTER OPENING THE DOOR, AND EVEN AFTER i LOCK IT. NEEDLESS TO SAY THEY HAVE ORDERED ME A NEW RADIO, UNDER WARRANTY OF COURSE/
Fortunately, I have never encountered such a problem. My car works like clockwork. However, I think you should completely replace the panel. There are many options in online stores. Btw, I wouldn't say I like to make large purchases online. I have only bought https://www.vont.com/product/vont-bulb-color-smart-light-bulbs-smart-bulbs/ last month. You can also try to contact qualified specialists in your city. The cause of the malfunction will be revealed after a detailed technical inspection. I hope everything you will be able to find a way out.
1 - 3 of 3 Posts
