1 - 5 of 5 Posts
Dupli-Color has brought out a new version of self etching automotive primer that will ETCH PLASTIC!!!
This can solve a LOT of the adhesion problems with engine covers and other plastic parts under the hood
you still use a sandable primer on top of it
Dupli-Color® Self-Etching Primer
Self-Etching Primer etches and primes in one easy, convenient step and can be used under all of today's automotive finishes.
  • Superior adhesion
  • Perfect for spot repairs
Recommended Uses: For most plastics, fiberglass, bare steel, aluminum and stainless steel.
thank you for posting this, I need to see if I have this at work. If not then I need to visit the other auto sites in the area.:thumbupleft:
I ordered two cans direct from Dupli-color - it will save HUGE headaches when painting engine parts
Well what we have at the store is from Rustoleum, but it is etching primer, that should work too.
double check it - does it etch PLASTICS?
1 - 5 of 5 Posts
