Oil Change/Reset | Challenger Life Forums
Oil Change/Reset
Discussion in 'Dodge Challenger Detailing and Maintenance' started by Lucky 13, Dec 20, 2011.
  1. Lucky 13
    Lucky 13 Member
    Jun 11, 2011
    188
    14
    18
    Cedar Hill, TX
    I took my Challenger in to a local shop to have my oil change and the guy didn't have a clue on how to reset the odometer for the next oil change. Now the light comes on stating that my oil needs changing every time I start my car. It's so aggravating. Does anyone know how to reset this? I would hate to have to make a trip to the dealer for something so minor.
  2. DragonFire
    DragonFire Well-Known Member
    Feb 28, 2010
    1,223
    33
    San Antonio, Texas
    Change Oil Message (Base Cluster)
    Your vehicle is equipped with an engine oil change
    indicator system. The “Change Oil” message will flash in
    the instrument cluster odometer for approximately
    12 seconds after a single chime has sounded to indicate
    the next scheduled oil change interval. The engine oil
    change indicator system is duty cycle based, which
    means the engine oil change interval may fluctuate
    dependent upon your personal driving style.
    Unless reset, this message will continue to display each
    time you turn the ignition switch to the ON position. To
    turn off the message temporarily, press and release the
    TRIP ODOMETER button on the instrument cluster. To
    reset the oil change indicator system (after performing
    the scheduled maintenance) perform the following procedure:
    1. Turn the ignition switch to the ON position (do not
    start the engine).
    2. Fully depress the accelerator pedal, slowly, three times
    within 10 seconds.
    3. Turn the ignition switch to the OFF/LOCK position.
    NOTE: If the indicator message illuminates when you
    start the engine, the oil change indicator system did not
    reset. If necessary, repeat these steps.
  3. Lucky 13
    Lucky 13 Member
    Jun 11, 2011
    188
    14
    18
    Cedar Hill, TX
    Awesome thanks for the help!!!
  4. deranged
    deranged Well-Known Member
    Aug 4, 2010
    1,756
    57
    Central Illinois
    Search Challenger tips and tricks. Lots of cool stuff!
  5. IntimidatorR/T
    5,417
    153
    my oil change warning started going off this week, forgot how to shut it off. still a little early for me to change it , but it will be soon.
challenger oil change reset
how to reset challenger after oil change 2010
how to reset change oil light on a 2010 challenger
how to reset the change oil warning on a 2010 challenger
oil chance reset challenger
reset my change oil sign in challenger
