1 - 10 of 10 Posts
So I keep reading that I should pull Fuse #2 so it can reset the adaptives. I have Predator and thought that I could do it with it without having to pull any fuses. If this is true, I can't seem to locate it in the menu or don't know the wording to look for. Anyone help a brother out?
Thats what I do at the track. Go to the quick adjust menu in the performance tune section
Just an FYI... We have a Predator menu on the site at http://challengerlife.com/diablo.html Comes in handy when you want to look through the menu without having to use the Predator.
btw, it's Performance Tune > Quick Adjust > Transmission > Reset TCM Adaptation.
Very cool menu! Thanks for the link.
So it's under transmission. No wonder I couldn't find it. So reseting TCM Adaptation under the transmission Quick Adjust is the same thing as pulling Fuse #2?
Seems to me people talking about it reseting the computer for the engine adaptives, not transmission. I guess I am just confused. :bigthinking:
You're right. The transmission adaptives are not the same as the fuel adaptives that are reset by pulling #2 fuse.
Discussion Starter · #6 ·
So does pulling #2 fuse reset BOTH fuel and transmission adaptives or do I need to do both the fuse and the predator transmission reset?
They are independent.
Discussion Starter · #8 ·
So would you recommend doing both the tranny and the fuel adaptives after installing a CAI/CAT-BACK/ and predator? Or just the fuel adaptives?
Fuse 2 for sure. The tranny if you have been driving like like a granny.
1 - 10 of 10 Posts
