Like everyone else I wanted to order functional hood scoop bezels so ambled over to Ebay to get some. Started bidding kept getting outbid even when the item I was bidding on in the 30.00 plus range had an IDENTICAL item unbid upon in the NEXT listing. Got suspicious pulled details on ALL of the deals by the most popular seller and found problems. Four bidders were consistently jumping in at the 15.00 level bidding to 40.00 45.00 then dropping out. Over and over the same pattern showed up.
ALL THE TIME THE SAME IDENTICAL BEZELS WERE LISTED WITH NO BIDS!!!!
I informed both the seller and made a complaint to Ebay which is under investigation. However jumped on this morning and found this
Pattern continues on items #360207802038 / 390119015695 /360208255464 / 390119006114
All bidding activity from the four apparently bogus bidders between $15.00 - $45.00 then drop
First bid item # 360209344008 no activity
Items # 360209633351 / 360209601376 / 390120758592 / 360208951361 / 360208180102 / 390119094397 /360208272065 / 360208358069 / 360208301359
IDENTICAL ITEMS TO ABOVES WITH NO BIDS YET!!
WHY would four bidders jump IN at 15.00 when there are NINE sets with starting bid of 0.01 CENTS - AND if you can bid at 0.01 - WHY are they jumping in at over 30.00 in some c ases??
AND if they are REAL buyers WHY DONT THEY BUY ONE OF THE MULTIPLES THEY HAVE BID ON???
I will tell YOU when Ebay tells ME!!!
